RCU Forums
-   RC Flight Simulator Software (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/)
-   -   Aerofly Pro Game commander help (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/1018380-aerofly-pro-game-commander-help.html)
Flightspoiler 08-03-2003 04:39 AM
Sim works great using own tx. Tried game commander with less joy. Can not seem to calibrate the game commander. I've tried as per instructions to go under control panel in XP and custom assign a 4 axis 1 button control. What I seem to get is the left stick fore and aft movement giving elev pitch result, left to right giving rudder (which is normal). Same goes for the right stick fore and aft is throttle, left to right ailerons (normal). In other words pitch and throttle control is backwards.
I've tried to calibrate in the sim itself, but it seems that it must be first calibrated in windows format before going to the areofly sim.
Any suggestions???
Thanks Al
Flightspoiler 08-03-2003 05:32 AM
Seems to have fixed itself. (finger trouble!!!) Although the calibration still shows what I said, flying the sim tells otherwise. Go figure!!!
I have no idea why the sim would behave differently from the cal setup.
Has anyone seen this before or had I just experienced one of those "once in a life time blonde moments"?
Cheers Al
Avistar23 08-10-2003 11:07 AM
Im having a problem, aero fly wont find its own controller it will find mine but not the comander.. im stumped.... seems to be similar to your issue... i set up the 4 axsis 1 button and xp found it.... but aero fly wont....
Flightspoiler 08-10-2003 03:29 PM
Make sure you have deleted any previous game devices like your joy stick controller in the game controller folder under control panel. The manual says this will prevent any conflicts between controllers.
I'm also running XP. It took awhile to figure it out.
Let me know how your making out.
Good luck
Cheers Al
Avistar23 08-10-2003 11:35 PM
Hmmm this is weird Ive tried every thing i know short of throwing the controller in the garbage.
Mike Ledbetter 08-11-2003 05:34 AM
I assume you
went into Controls and picked the dot next to Joystick as your controller after using the Tx?
Regards,
Mike Ledbetter
Tspin 08-21-2003 02:47 AM
I sent it back and use my Futaba T6XA :D
