FREE RC Flight Simulator
Hi,
Here there is a new free simulator http://www.rc-flight-simulator.com Is seem working with all RC controllers. My optic6 is working with it realy good. They using Havok for the physic and seem to be very realistic. I hope they will add more models and landscapes... What you think about this sim ? Let talk about. |
RE: FREE RC Flight Simulator
The site asks for a user and password.
No more password. I don't know what happend.</p> |
A good start! I am not a helecopter pilot and don't read French, but it looks pretty good. I did notice that while hovering the copter it would suddenly take off in reverse for no reason. And after I had set the resolution to 1920x1080 to match my screen, and then went to one of the admin screens the content extended off the bottom of my screen so that I had to reduce the resolution to see all of the dialog. Don't stop now! |
I can't make it work whit FS CT6B. And I am using it wht Clear view RC sim. Could anybody explane me how to make it work if it is possible. Best regards.
Hi,
Just look in windows setings of your controller. You can check the axes and see what axes are assigned in hardware to your controller. ( mode 1 Mode 2.....) If you have problem to assign the axe in game just move the axe before clicking ,the one you whant to assign , and take it to the max direction while clicking. This kind of effects arrive because some controllers send info continiously to windows from others boutons or axes. Anyway there is a file that you can edit with notepad where you can manualy assign the axes if you need. > ConfigRc.cfg x 0 0 0 0 0 0 y 1 0 1 is for the first axe and is assigned to Y z 0 4 rx 0 0 ry 0 0 rz 0 0 Assign a value 1 2 3 4 ... to witch axes for exemple 1 for Y 4 for Z axes Let me know if you have any problem I can assign for you the axes. JYs |
| All times are GMT -8. The time now is 01:40 AM. |
