Phoenix With JR 9303
I have the Phoenix simulator and I am using my JR 9303 with it. I read while setting it up that you should use heli mode on the transmitter regardless of what type models you fly on the sim. However, I am having a problem setting up my flap switch in heli mode to work the flaps on the airplanes. It's as if there is no output from the switch which leads me to believe it is a setting on the transmitter. So I guess my question is what switch does the flap switch become in heli mode and what setting do I need to change in the transmitter to activate the flaps?
Thanks, Brian |
RE: Phoenix With JR 9303
I'm not at home at the moment but I believe the 3 position switch above the right hand stick controls the flaps, at least it does on the Parkzone P47 and Stinson Reliant models. My problem was when I calibrated I didn't start off with this switch in the full down position. I recalibrated starting with it down and then when it came to the screen to try out all the switches, it then worked properly per the response bars on the screen. Using a 9303.
| All times are GMT -8. The time now is 09:55 PM. |
