RCU Forums
-   RC Flight Simulator Software (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/)
-   -   Aerofly Pro - New Models - Loading Probs (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/1065970-aerofly-pro-new-models-loading-probs.html)
UKflyer 08-18-2003 01:52 PM
Somewhere in this forum I found a link to WWW.RCSIM.DE, and having registered, downloaded several new planes.
The problem is, having unzipped them into the correct directory area, getting them to load properly.
I found that with the Candyman Mustang I had to change the version no. in the .TMD file from 1.5.0 to 1.2.0. This seems to work fine (except that the flaps move UP instead of DOWN!!), but doesn't seem work for other aircraft.
Has anyone else tried these downloads with a greater amount of success?
Dave :confused:
Mike Ledbetter 08-18-2003 04:23 PM
That site is great, but I can't get certain of the models to work either. Candyman is one. Most of the models work fine.
UKflyer 08-18-2003 05:44 PM
Seems strange Mike that Candyman is the ONLY one that I've managed to get working!
What models do you recommend, and did you have to mess around with the .TMD files?
Candyman is great (Unless you try to use flaps!)
UKflyer 08-18-2003 07:45 PM
Sorted it guys!!
I should have RTFM'd properly ........ When you create the directory for the new aircraft, it MUST be exactly the same name as the first part of the ZIP file ........DOH!!
Ian.W 08-20-2003 05:49 PM
ive still done this and i cant get the raven :(
UKflyer 08-21-2003 02:38 PM
I've had no probs with the raven ....... flies great!
Do you get the spinning model load up properly on the front screen?
Ian.W 08-21-2003 07:19 PM
how did you get it to work?
Mike Ledbetter 08-21-2003 11:55 PM
I can't get the Raven to work, or candy man either. Most models are no problem. I download from:
http://www.rc-sim.de/index1.htm
Regards.
DominicM 08-22-2003 08:18 AM
I'm having problems getting the Twinjets to work but I suspect it's the folder naming issue.
Quick question - Is there an easy way (like in G2) to make the models visually bigger ? The Spitfire is tiny sitting there on the runway.
Cheers - Ditchit
Would add that I prefer Aerofly Pro to G2 having had both.
Ian.W 08-22-2003 11:08 AM
the view your from is far too high, press page down to get him a realistic hight.
Ian.W 08-22-2003 01:03 PM
anyone know how i can get the raven to work?
Ian.W 08-22-2003 05:50 PM
anyone?
miskin 08-22-2003 06:40 PM
edible i just downloaded the raven and it worked fine
i saved it to my desk top unzipped to the aircraft folder in aero fly
and hew presto im flying it :)
cant get any of the twinjets to work though:( (dam i wanted to get one )
UKflyer 08-22-2003 06:53 PM
Hi Ian / Mike
I think I know why you are having probs with the Raven ......
The ZIP file is called Raven_ma.zip, this holds a separate folder called Raven, which in turn holds the 5 files ...... note that the 5 files are called Raven.*** and NOT Raven_ma.***
Make sure the aircraft directory in this case is called Raven.
DITCHIT ..... The Twinjet is similar .... the aircraft file has to be AS_Twinjet, not AS_Twinjet_upd, and don't forget to put the Twinjet.wav file in the sound directory.
Bob is most definately your Father's brother!! ...... ENJOY
Dave
miskin 08-22-2003 07:40 PM
hi ukflyer
thanks for the info i now have the twin jet up and running :)
DominicM 08-23-2003 09:30 AM
I don't. You wouldn't think I wrote software for a living would you....Ahhhhh !
Do I need the Volume 1 add-on to use the TwinJet and Kantana ?
I have AS_TwinjetW.*** in a AS_TwinjetW subfolder of aircraft. Still no luck.
miskin 08-23-2003 10:04 AM
ditchit do you want me to email you my folder with the twinjet in it..
if you do email me and i will send it to you..
Ian.W 08-23-2003 04:08 PM
still dont work :mad: nor the katana
Ian.W 08-23-2003 07:56 PM
nor my twinjet :mad:
Ian.W 08-24-2003 11:18 AM
anyone?
DominicM 08-24-2003 06:13 PM
Thanks for the offer Miskin but I don't reckon it would sort the problem. Advise you remove your email address as well otherwise you will get tonnes of spam.
I reckon that you need Volume 1 to use some of the other Models like the Kantana and Twinjet. It's not that they don't work...they just don't appear in the model list.
Anyone just got the standard version with the patch (not volume 1) and got these models working ?
miskin 08-24-2003 06:28 PM
thanks for the advice ditchit my post has been edited
oh and i do have the volume 1 upgrade
Ian.W 08-24-2003 08:14 PM
mmmm, maybe thats my problem :(
