RCU Forums
-   RC Flight Simulator Software (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/)
-   -   Real Flight 7.5 view issue (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/11606785-real-flight-7-5-view-issue.html)
AllModesR/C 11-16-2014 05:25 PM
In my RF 7.5 when I click view and camera type I can not select any other choice than fixed position. And when I click on camera position the only choice I get is pilot spawn. Does anyone know why? It is like this with all aircraft even the quad drones.
da Rock 11-17-2014 06:48 AM
It's been that way for a couple of releases.
Why? The designers either don't care about offering more power, don't know how to do so in today's environments or don't have the manpower or budget. It's not unusual for software companies to focus their manpower on current marketplace issues and set back other projects in order to keep pace with the public's latest interests. (That has usually been graphics advancements.)
AllModesR/C 11-17-2014 06:02 PM
It is very strange they put the option into the software when the feature does not really exist.
AllModesR/C 11-26-2014 09:32 PM
I just found that the chase and FPV option does indeed work but only at certain flight areas. For example it does work at Joe's Garage, I was flying so far away from the airport I got lost, LOL
opjose 12-27-2014 11:53 AM
huh?
The correct answer is that the OP is using a 2D airfield with only one spawn point.
if he chooses a 3D airport he can switch view points.
it has been that way for more than a couple of releases....
AllModesR/C 12-27-2014 08:21 PM
It would be real interesting if they added a GPS navigation tool and full size airports like ORD or LAX that you could fly to. That would be awesome.
on_your_six 01-09-2015 10:06 AM
It is an RC sim, not a general aviation sim. If you want that check out MS Flight Sim or X-Plane.
RichinTx 01-09-2015 06:42 PM
I think you can only have other views at fields that are graphically generated. I noticed that I could only have the fixed views at the photo fields...where the surrounding scenery is made up of photos. At the fields where the surrounding terrain is computer graphics I can select the other views.
opjose 01-09-2015 08:14 PM
Correct, and if one thinks about it, that makes sense.
"Panorama" airfields are basically 2D photos projected onto the inside of a virtual circle, the center of which is the pilot's view point.
Collisions at these 2D airfields are handled by imposing an invisible 3D object onto the image in the background. That gives the illusion of a plane crashing into something in the photo.
If you shift the pilot's viewpoint, the illusion is broken, and the collision objects also appear displaced.
This is how most panoramic sims display their airfields.
3D ( laughingly called "4D" by another sim ) airfields are completely computer generated
Since the entire "world" is mathematically generated, the pilots view point can be moved with perspective, 3D and parallax all coming out correct, so much so that you can take these fields one step further and even use Stereoscopic 3D for depth perception.
3D RC fields are of course much harder to render, require better graphics engines and more processing power.
It is unfortunate that the graphics engines in 3D RC sims has not yet approached the fidelity of top tier computer & video games. In turn that causes many neophytes to exclaim that 3D RC sim airfields look very "cartoony" or "unrealistic" compared to 3D airfields.
Yet you can't have leaves fall off a tree when you clip it with a plane in a panoramic airfield, you can't move the view point, etc. etc. etc.
gliderguy100 02-08-2015 07:18 AM
Thanks for clarifying the airfields choice for the camera position option. I had read that those views were only available at some airfields but had not yet found them. (just got this thing a couple days ago). That's fun! I like the "chase" position with the Yak 54. pretty sweet. But I have another question... about aero towing scenario. It says to use channel 8 t release the tow line but I'm using just a 6 channel Spektrum radio. Is there some other way to release the to line? I've tried about everything I can think of with no luck. Thanks.
AllModesR/C 02-08-2015 03:33 PM
I don't know how to release the line either.
Bax 02-13-2015 09:20 AM
The "O" key should release the towline.
f16man 02-19-2015 12:54 PM
Real flight is to train for rc flight without crashing not gaming IMO.
