RCU Forums
-   RC Flight Simulator Software (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/)
-   -   EXPOTENTIAL G2 (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/1216903-expotential-g2.html)
sky warrior 10-21-2003 04:46 AM
EXPOTENTIAL G2
Hi
I have finally got my (Shuttlecomputer which is great ) and Windows Xp which seems to run G2 fine with no problems so far. However I want to tone down the response from the G2 controller to give me less sensitive stick feel ie an expotential style of feel.
Is this possible using the G2 controller or is it only with a full on Trans + interface?
SeenMCrash 10-21-2003 05:02 PM
RE: EXPOTENTIAL G2
I'm not sure about expo, but I know you can lower the control throw. You must make a copy of the aircraft, and then go into control surfaces. There, select the surface you would like to edit, and lower the numbers in the percentage boxes. (I'm sorry if these instructions aren't perfectly clear, haven't been on in a while). Lower them little by little until you get the desired feel. -Andrew
sky warrior 10-24-2003 08:38 AM
RE: EXPOTENTIAL G2
Andrew
Thanks for that it works fine and no doubt there will be more questions where that came from,like Can I turn on smoke trail and ith what switch?
Bye
w8ye 10-24-2003 03:37 PM
RE: EXPOTENTIAL G2
I have the Deluxe version and you can add exponential to all axis. Go to the controller section and nose around.
I changed the controls for Mike Cross's plane so that I could fly it on high rates. Works for just this plane and was a real nice thing to be able to do.
Good luck,
Jim
