aircraft downloads-problem
I own the G2 and purchaced volume 1. I have down loaded air fields that went right into the sim. When I down loaded the aircraft, I could not get them into the sim. Any feedback on this would be greatly appreciated.[sm=drowning.gif].......Also ,I only downloaded those aircraft that were in G2 and volume 1
RE: aircraft downloads-problem
Flying Rubbernutz,
Can you hum a few more bars? Are you getting any errors when you try to load a plane, or do they just not show up? I have 84 files of airplanes that normally come as self-extracting executibles if you want to give any a try. Just make sure that your application path is either the DEFAULT or ensure the path to your aircraft folder is right. Can you see the .pln and .eng files you extracted in your "planes" folder? Let me know and I will see how else I can help. I also have over 190 trim schemes. |
| All times are GMT -8. The time now is 12:00 AM. |
