RCU Forums
-   RC Flight Simulator Software (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/)
-   -   G2 Question (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/1437310-g2-question.html)
mailman77327 01-16-2004 06:31 PM
G2 Question
I "Scaled Up" a number of my G2 planes and I was wondering if there was something I was doing wrong...
As it seems that they "Sink" into the ground.
Please explain what I did wrong.
Thanks in Advance,
Chris
SteveGB 01-16-2004 07:23 PM
RE: G2 Question
You did nothing wrong. You do, however, have to go back to the aircraft editing page and lengthen the landing gear. Try different values for the main and nose or tail wheels until you get a look you like. It seems as though G2 does not properly position the plane in relationship to the ground when the aircraft is enlarged. You then have to adjust its position relative to the ground by making the gear legs longer.
Also, try to maintain the relationship between the main and the nose gear. Otherwise the plane will sit at a different angle or even fall back on its tail if it has nose gear. Hope this helps.
Steve
