RCU Forums
-   RC Flight Simulator Software (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/)
-   -   remove transmitter module? (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/1525461-remove-transmitter-module.html)
drbutton 02-13-2004 06:22 PM
Hello everyone,
I have the AeroFly pro sim, and I had heard that it might be a good idea to remove the transmitter module when using your tx as an interface. This way, you are not irradiating and possibly stressing the transmitter with the antenna down. Has anyone done this? If so, how is it done?
miskin 02-13-2004 07:10 PM
RE: remove transmitter module?
drbutton
i have a futaba FF6 i always remove the crystal then the battery last twice as long :D
i must admit i never used to untill i was talking to another club member he suggested it and ive never looked back ...[8D]
drbutton 02-13-2004 07:23 PM
Sounds good- I'll give it a try. Thanks!
rajul 02-13-2004 09:01 PM
John, which Tx are you using with your AFP ?
Geistware 02-13-2004 09:22 PM
If your 8U or 9C plug is wired correctly, you don't have to remove anything.
drbutton 02-13-2004 11:27 PM
Hitec Laser 6
DTB 02-16-2004 04:40 PM
I have a Futaba 9C and I always remove my Module before using it with Realflight G2. The green RF light on the Tx is on while using the simulator, so that tells me that it is emitting a signal. Plus my battery last a lot longer with out the module in place while I am seating at the computer. With the green RF light on and the antenna down for an extended amount of time, this will make the internal componets over heat and cause problems in the long run. It only takes a second to remove the module. Just be sure to place the module out of harms way.
