G2 custom color scheme problem
Having issues when I use Paint Shop Pro to edit the .tga files to make my own scheme on a CAP 232. The canopy and both sides of the fuse below it go invisible. Any suggestions? :confused:
did i do that?
there should be a tool that says transparent and no that says non-transparent... highlgiht the area that (canopy) and then hit your non-transparent tool. wolay the canopy will not longer has disappeared.... talk at you later
| All times are GMT -8. The time now is 05:46 AM. |
