RealFlight G2 model question
Can any one tell if there is any difference between the same type of models when using exactly the same parameters. What I mean in example if you define all parameters for Edge 540 exactly the same as for CAP232, will these two models fly the same? Or there is some "flying behavior" built into model.
Putting the question other way: is there any difference between models other than the configuration (engine, wings etc.) and 3D view? RysiuM |
RE: RealFlight G2 model question
Good question!
If you change everything (including the airfoil) I believe they will fly the same but look differently. I have not tried this ... Carl |
Sounds like a good experiment........:D
ORIGINAL: glowplug Sounds like a good experiment........:D Now this thing is very snapy and has tip stall like a real CAP has. I'm not sure if it flyes like my scale Edge. I'm not saying, that RealFlight is not accurate. I've been playing with different simulators and in my subjective opinion G2 is the best for the reality factor. Good for practicing all new and dangerous things (pressing space bar doesn't cost you 1000 bucks). I just would like to know the limits it has. I mean the true, not the marketing BS or competitor's pissing. Anyone from RealFlight is reading this? If you don't want to publish ambarasing facts (again because of marketing BS) please do not hesitate to pm me - I will keep the secret[8D] RysiuM |
| All times are GMT -8. The time now is 03:26 PM. |
