RCU Forums
-   RC Flight Simulator Software (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/)
-   -   Another frame rate question for AFP (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/1865808-another-frame-rate-question-afp.html)
spre0042 06-01-2004 11:34 PM
Nobody wants to reply to my other post. Please, if any body has any advice, I'd like to hear it. I'd like to know if I need a better video card or if my problem is something else. What kind of frame rates are people running AFP on labtops getting, and what kind of graphics card are those folks using?
I have a pentium 4 with 256 Mb ram
with ATI mobility radeon 7500 video card with 32 Mb
Please tell me if the following sounds too slow for my setup. I get a frame rate that dips into the teens even for the less complex sceneries. However, it sometimes is as high as 70 FPS. I can't even fly the more complex OMP planes because the screen looks like it is in slow motion. Is this just a problem with my video card? I'd like to know what other people are getting with similar settups, or even with other settups, to get an idea of how my frame rate compares.
rajul 06-02-2004 12:07 AM
RE: Another frame rate question for AFP
spre, your setup seems OK with me. In fact I am using a more "primitive" card GEForce4 MX440 and I'm getting a fps of 80-100, but with less demanding sceneries e.g. monument valley. Do you have any programs or spyware running in the background ? They can take up a lot of resources. You need to disable all of those. Also try using a simpler scenery without any clouds, trees, etc. Let me know how this works for you.
stomper 06-02-2004 07:27 AM
Whoa
Looks like we have a new Moderator here at RCU!:)
Best of luck Rajul.
rajul 06-02-2004 08:28 AM
Thanks Stomper ! Just lending a helping hand..........
pache11 06-02-2004 10:23 AM
Disabling anti-virus, esp Norton can pick up frame rate quite a bit. Keep killing unneccesary processes in the task manager. Keep windows startup items to a bare minimum, or in extreme cases use a "clean" boot partition just for games and flight sims.
joebob 06-02-2004 11:19 AM
Droping your color depth to 16 bit will also help a lot. I pretty much doubled my frame rate that way. Everything looks the same if you don't use smoke...
spre0042 06-02-2004 03:02 PM
I had my color already at 16 bit. It sounds like my graphics card should be OK. I might just need more RAM. Thanks guys.
Any other replies to get a better idea of what other people are getting would be appreciated.
RSands 06-02-2004 06:48 PM
Reason for edit: Missed the laptop thing 1st time around. May not apply:
Had a similar problem with my PC, 256MB ram on a AMD @ 1.6, with a decent Radeon card with 32MB (older card though). A 5700Ultra fixed the problem (128MB vid ram). Can now run the complex sites at 1024x768+ with no hesitation and decent frame rates. Do what these guys suggested, make sure you've got the latest sound & vid drivers and divx is up to snuff, but the 32MB vid ram may be the issue, and your just seeing a temporary lag when it has to load new maps to the card.
