multiplayer on realflight
hey guys, i was wondering if anybody knew how to set up the multiplayer function on realflight so you can fly with people on the internet. I have dsl internet and i can't ever connect with anybody to fly with them. All info is appreciated.
RE: multiplayer on realflight
Since you are using DSL, I imaging your DSL router(if you have one) has a firewall. If that is the case, you will need to find out what port it has assigned to RealFlight to be able to play. Or, to make it easy, you could simply disable your firewall.
You probably have to open ports on your firewall. G2 uses one set of ports to connect to a multiplayer session, and then another to actually "play." Here are the port numbers from the Knifeedge support site:
Using RealFlight G2 Connection Ports for Client Configuration Ports for Host Configuration Initial TCP Connection 6073 Outbound 6073 Inbound Subsequent UDP Inbound 2300-2400 2300-2400 Subsequent UDP Outbound 2300-2400 2300-2400 PM or email if you are still having trouble. Carl |
thanks guys i appreciate the help i will try your suggestions when i get a chance.
| All times are GMT -8. The time now is 07:58 PM. |
