AFP "Interface Cable" problem...
Is it normal to have to have the "Interface Cable" plugged into the serial port, even if I just want to use the "TX" that comes with AFP? I don't have any other radio, I just want to use the one that comes with AFP, but the sim won't run unless the interface cable is also plugged in.
Thanks, Roger |
RE: AFP "Interface Cable" problem...
Yeah both will have to be plugged in. One goes into a com port and one into a game port. The game port is obviously the interface you are using. The other one will contain the dongle the software needs to run.
| All times are GMT -8. The time now is 06:21 PM. |
