RCU Forums
-   RC Flight Simulator Software (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/)
-   -   G2 owners upgrading to G3 please read (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/2374533-g2-owners-upgrading-g3-please-read.html)
cfossa 11-25-2004 10:30 AM
Hi Guys,
While I'm not happy with the $25 "rebate" for G2 owners upgrading to G3 ....
If you have made the upgrade please compare the sims and let us know if the upgrade was worth the price.
(Please no AFP vs. G2/3 or G2 bashing .... looking for comments from G2 owners who have upgraded)
Thanks!
Carl
Matt Merciez 11-26-2004 08:18 AM
RE: G2 owners upgrading to G3 please read
Carl,
I had G2 for about a year and sold it a month ago in anticipation of G3. I received G3 two days ago and have been playing with it for quite a bit.
My overall impression of G3 is very good. The more I play G3 the more I like the sim. I do feel it is a worthwhile upgrade. The number of changes from G2 to G3 is very large and I would agree with the knife edge in considering this a new sim and not an !QUOT!upgrade!QUOT! from G2.
Graphics: The new graphics are very impressive. You will need a strong computer system to have good framerates with lots of eye candy. The developer did a nice job in giving the consumer the ability to change/remove graphical objects from the airfields to give individuals with lower end systems a chance to run the sim. There are numerous tweaks that can be done to the sim as far as graphics are concerned. The airport editor is very nice and quite intuitive to use. The graphics alone are a huge improvement and I thought the graphics in G2 were pretty respectable.
Physics: I initially did not like the changes to the physics engine but after playing the sim for a few days, I now really like the physics. The 3D physics are amazing. I personally have a Extreme Flight Yak-54 which is capable of some incredible 3D maneuvers. G3 comes with a similar Yak which I have been flying and I find its flight characteristics to be scary similar to the Extreme Flight Yak. I did have to make some minor tweaks to the exponential and throw settings for the Sim to get the plane to handle like my plane, but I now have a way to practice some wild maneuvers on the sim and not worry about destroying my plane. The sim handles the 3D manuevers extremely well.
Torque rolling with the Yak is difficult on G3. On G2 and the reflex sim, I found torque rolling to be too easy. I could torque roll those sims easily but when I went to the field it was not as forgiving. I am glad that torque rolling with G3 is challenging, for it is making me practice much more and hopefully that will result in better results at the field.
Ability to tweak: This is an area I really like with G3. The control features with the software radio are outstanding. You can create custom mixes (multi-point) just like if you had a JR 10x. I have used some multi-point mixes to mix out the pitch coupling on the Yak in the sim. The required mix was very similar to what was required for my own plane.
As far as I can tell you can change just about every physical parameter on the planes. This will give users the ability to create and tweak planes that match their own. With the potential large user base for G3, there is the potential to have some awesome planes to download off the net.
There are some bugs still in the software. The most significant so far is that I can't figure out how to export the color schemes to edit to allow for custom painted aircraft. Hopefully this will be fixed so or someone will educate me on the process. There are too many users out there that simply like creating custom paint schemes for this feature to not work.
Overall I am very pleased with G3 and would recommend the upgrade from G2. Just make sure you have a good computer to run the sim.
r1derbike 11-26-2004 05:41 PM
Matt:
Thanks for your observations!
Charles
cfossa 11-27-2004 09:26 AM
Matt,
Thanks! That was a great review. What do you consider a "strong" computer system? I'm running G2 & AFP on a P4 2.6GHz, 512MB Ram, and a GeForce 64MB graphics card. This is plenty for these sims, but not sure about G3.
Carl
Matt Merciez 11-27-2004 01:06 PM
Carl,
I have a Athlon 3200+ with 1 gig of memory with an ATI 9800 pro video card. I am running the sim at 1600 x 1200 and am getting around 40 fps on average with most everything turned on.
Your system should be OK. The only area that may be worthwhile upgrading would be your video card. I would suggest running the sim under your current configuration and seing how well it performs and if you are happy with that performance. If you want more eye candy, upgrade your video card.
r1derbike 11-27-2004 01:14 PM
Matt:
Are your settings for the Yak easily exported to email? I'd like to try your settings to see if that will tone-down coupling/snap problems in the Yak? Thanks...
Charles
I'm also running an Athlon 64 3200+, but only have an FX5200 video card in it...woefully inadequate!
Matt Merciez 11-27-2004 03:06 PM
1 Attachment(s)
Charles,
Here is the yak I am flying with. You will have to rename the file to Yak1.plnG3 for the file to work. Just place the file in your planes folder.
I have not mixed out the roll coupling but the pitch coupling is very close to be mixed out. I did reverse the low and high rates on the plane to make it similar to how I have my own transmitter.
I did wish the sim supported triple rates instead of only two rates for control throws. I believe if I used my own transmitter I can get the triple rates, but I prefer using the GP dummy box.
r1derbike 11-27-2004 05:44 PM
Thanks, Matt...my Super 7 should also support triple rates, with expo being one. I'm a bit disappointed in the jack for my Futaba transmitter; the jack on back of the interlink controller is not centered, and the plug on the cable will not seat into it, necessitating laying-down the controller to keep the cable somewhat steady, just barely hanging into the jack...very cheap. Also, my rudder/throttle stick is far from sticking straight-up. It is not bent. Seems the gimbal is machined pathetically.
These issues should have been taken care-of before shipping to market....
Charles
