need help with nexstar g2 realflight
just purchased a nexstar and was trying to use the training software. from real flight. my problem is that the throttle stick works backwards. forward for idle and fast when pulled back. the rudder seems to work ok. and the right stick the elevator control works backward. forward for up and pull back for down. then again the ailerons work fine. any help.
RE: need help with nexstar g2 realflight
Did you try the servo reverse switch on the Tx?
Carl |
| All times are GMT -8. The time now is 08:54 PM. |
