RCU Forums
-   RC Flight Simulator Software (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/)
-   -   Realflight G2 problem (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/2574337-realflight-g2-problem.html)
chudd 01-23-2005 11:50 AM
hi i eventually plucked up the courage to go out and buy the G2 software. i have a saitek p880 gamespad( with 2 analoge sticks which work like TX sticks) the throttle,rudder , and ailerons set up fine but cant get any response from the right stick, up and down movement. it is not the game pad because it works fine on FMS or Easyfly
the screenshot link of the G2 control setup is below.
http://img.photobucket.com/albums/v3...rolersetup.jpg
cheers
Dan
chudd 01-23-2005 12:18 PM
RE: Realflight G2 problem
and can you get leads which plug into your buddybox slot, then go into the pc via USB?
cfossa 01-24-2005 10:08 PM
Why not just use the G2 controller instead of a gamepad? The controller is a lot better.
Carl
wigsplittah 02-05-2005 01:04 PM
*cough*warez*cough*cough* *clears throat..
