Windows XP and G2 problems help
I hope some body can help with this a have a new computer with the G2 I allso since I donot have a game port I had to buy a USB convertor cable called a Rock fire to be able to connect the transmitter to computer .I followed all the directions for both the Rock Fire and G2 .The problem is that it refuses to see the game adapter soo it does not see the Transmitter.It keeps telling me that the game port is not alined or the drivers are not there.But in the contol panel the G2 cotroler is there but it will not let me chose it .It sees the Usb cable as new hard ware and tells me it is ready I go to control panel and it is there just like it is supposed to do .I hope some one can give me some help I have allready downloaded the upgrades to G2 and it still did not help.
Sometimes, USB adaptors which emulate other ports don't work all that well. You may want to install a sound card (example Sound Blaster Live) and use the game port on it.
You need to manually install the driver for the controller.
Here is how: For XP Go into the Windows Control Panel Go into System Go into Hardware Click on the Add Hardware Wizard Click on Next and let it scan just for the fun of it ( no choice) Click on Yes ( Already Connected) Click on install manually from a list Click on show all devices. Click on Have disk Copy Manafacturers files from C:\Program Files\RealFlight Click on next, Realflight driver should appear. Click on next Click on next Click on View/Change resources Click on Set Manually Make sure use automatic resources is selected Click on OK Click on Finish Reboot and you should be good to go. Copied from anouther XP-G2 thread Todd |
Thanks for the help
Thanks to every one that tried to help. I have it working great now.Maybe by spring I can try to fly my Helo with out the pucker factor kicking in
| All times are GMT -8. The time now is 06:10 AM. |
