G2 and Hitec Eclipse 7 ?
I have G2 and use the G2 transmitter. I use a Hitec Eclipse 7 transmitter to fly my real planes. Is it possible to use the Eclipse 7 with G2 so that I can experiment with programmable mixes on different planes?
RE: G2 and Hitec Eclipse 7 ?
I don't know about G2, but I can do that with my JR 6102.
I also have the Eclipse 7, and I got G2 to work using the Eclipse 7.
The cable I used came from http://www.tti-us.com/sim You need to install a freeware tool to add a parallel joystick that G2 then can use as controller. I don't have the details on the freeware tool right now. [Edit] Freeware joystick tool needed to run G2 with your Eclipse 7 : http://www.tti-us.com/sim/picjoy.html |
| All times are GMT -8. The time now is 05:49 AM. |
