Reflex XTR requirement question?
Will it run on P3 1Ghz okay or do I need to go with G3 or AFPD?
thanks, James |
RE: Reflex XTR requirement question?
Go to their web site and download the demo, it will tell you whether it will work on your computer or not (it should work on that computer).
[link=http://www.reflex-sim.dyndns.org/reflex-sim/shop/catalog/default.php?cPath=23&osCsid=deb7cd8eaaf53aad6b90fa 0ca4701c9b]Reflex Demo[/link] |
Hi James,
I've being running Reflex on mine with good results. I have a PIII 1 ghz and 512 MBytes PC133. My videocard is a Leadteck GF2 - Pro 64 megs. Be sure to have at least a video cards with this performance level, much more than this is ineffective. My Reflex runs stable at 21 fps and 28 fps which are both ok. Depending the scenery it falls to 17 fps or less which is no good!! You, like me, will have good results on 2 or 3 of it's standard sceneries. I can't remember its names of course. BTW. My impression is that Reflex requires less machine power than G2. I suggest reinstall Windows before installing Reflex. Latest driver versions is a must. Ricardo |
Actually reflex requires "very much more" system grunt than G2.
Reflex is very realistic, but is heavy on system resources. Generally you would aim for a CPU 1.8Ghz, 512MB Ram 40Gb HDD and a 128Mb Graphic card MInimum.I have run it on this system and a 32mb Graphic card but it was slow and choppy |
ORIGINAL: RicPall Hi James, I've being running Reflex on mine with good results. I have a PIII 1 ghz and 512 MBytes PC133. My videocard is a Leadteck GF2 - Pro 64 megs. Be sure to have at least a video cards with this performance level, much more than this is ineffective Ken |
| All times are GMT -8. The time now is 02:46 AM. |
