RCU Forums
-   RC Flight Simulator Software (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/)
-   -   INTERLINK NOT DETECTED (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/3378885-interlink-not-detected.html)
Fire_Faith 09-21-2005 06:21 AM
Hi all,
i am facing a prb with my interlink of G3 of Real Flight, Windows XP is not detecting the Radio Controller. I don't know wht is the Prb. Do i need the USB driver?. My windows says its Unkown Device attached to USB port.
But other USB Devices are working Fine on the same Windows XP.
jaafit 09-21-2005 12:05 PM
RE: INTERLINK NOT DETECTED
You shouldn't need to install the driver, XP should do that for you.
One thing you can try is to unplug all USB devices including the interlink, restart your computer, then plug in the interlink.
If that doesn't work, tech support might be able to help you better than I can in this case.
http://www.realflight.com/techsupport.html
horace315 09-21-2005 03:41 PM
try to reinstall software you will have to do an uninstall first,usb is usb,xp is plug and play.it is possible that your usb cable is bad on your controller.try the reinstall first though.real flight has a faq at their web sight of known issues.did you put in the serial number for the controller?
