G2 Trim Schemes...how do I change them ?
I have downloaded a couple of trim schemes, but just don't find an indication how to apply them to my downloaded planes ?
I am new to G2, so can somebody please help here ? Thanks |
While outside of G2 (it is not running) and using your Windows Explorer go to PROGRAM FILES and then to REAL FLIGHT and then to the COLOR SCHEMES folder. There you will see file names of those color designs/schemes that you downloaded (they will have a recent date. You have to "install" them by either right or left clicking on them. Which click to use, depends upon where you downloaded them from. Try your left click first and follow the directions.
If you download from this site: http://zeus.rcwizard.com/fubar_hill/G2.htm you have to do a right click. This creates another subdirectory and in it is your active color scheme file. MOve this file out of this subdirectory and on to Real Flights main listing of color files. whew!!! Once done, you can then delete the empty source directory as well as the original zipped directory as these are not needed anymore......they just transported the file that you wanted. Be careful and know what your are deleting though. Then you can start up Real Flight and your downloaded color schemes should be listed along with Real Flight's stock schemes. Hope this helps! |
Yes it did. Thanks a lot
I guess you need my CG Jungmann I made for Realflight Ulf. I also made the trim scheme like mine. You should try it. You will want one! I threw her into a knife edge and she flew just as solid as upright.
1 Attachment(s)
hey billy i finally got some pics of my garage and prof edge
i gotta send them to ya via email :P its not a 1000 mile stare but its 900 !! |
Send them on. We will also have to work on the way you hold that thing.
Hey Billy, where can I download the Bucker ? Do I need any add ons ?
| All times are GMT -8. The time now is 05:02 AM. |
