Help with Reflex and Futaba 7C
Well I figured this would happen. Reflex is not recognizing my radio (Futaba 7C).
Error says "No Reflex-Interface could be detected" Is this different from the "turn your transmitter ON error"? So i did some searching and found out about the resistor mod. De-soldered the resistors on the USB board but I think i damaged a neighboring part in the process. Help!........what do I do now? Does any vendor sell just the USB adaptor? I'll try contacting Reflex directly but Im sure that will take weeks..... |
RE: Help with Reflex and Futaba 7C
That smells: [link=http://www.reflex-sim.dyndns.org/reflex-sim/shop/catalog/faqdesk_index.php?faqPath=53&language=en]Reflex waranty[/link] You googled a lot to find the wrong task for a different error and you did NOT find the most obvious information? Instead, you are looking for an illegal source? As I said, it smells.
Thanks Kurt.
Not looking for an illegal source.........just a vendor here in the US so i dont have to ship to Germany. I have the USB. What task do i perform for that No-Interface could be detected? I thought it was the resistor mod?? And as for that smell......its probably just your upper lip.:D |
[link=http://www.modelrectifier.com]mrc[/link]
| All times are GMT -8. The time now is 07:00 AM. |
