Reflex & Torque Training
Am VERY new to planes but have been getting stick experience on the Sim with Heli's.
Will be spreading my wings as I am interested in both aspects. What on earth is the Torque training mode all about? Plane sits bolt up-right (vertical) a couple of inches off the ground and simply drops down! Do not understand this concept or what to do. Have played with throttle but the bird just falls. Any help be gratefully taken on board. CHAKA |
RE: Reflex & Torque Training
If you are using a plane that is meant for "3d" (power more than 1 to 1 thrust to weight ratio) you can practice hovering. watch videos of real planes doing it and you'll get the idea. Reflex lets you put it in this mode to practice one control surface at a time until you can combine all of them. Throttle, elevator, aileron , and rudder.
Chris |
Thanks for that.
Guess if you select model capable of 3D Reflex assumes you know what your doing! I will look for one W-A-Y down the list lol! CHAKA |
| All times are GMT -8. The time now is 08:44 PM. |
