Building own flying fields in g3(need help)
im plannin to build my own field in the realflight g3, and i want to start from scratch, the problem i am having is trying to find an object, for example, if i want to put benches or tables somewhere, where do i get the tables, or putting a runway somewhere. Sorry if this is confusing.
Can anyone help me |
RE: Building own flying fields in g3(need help)
Yea same here, recently just discovered option of creating fields. For some reason I have been completely oblivious to it before.
hey, Its easy for me to edit a pre-made field, but when i start from scratch, i dont understand where to get the objects from
You get objects from the Object Palette in the upper-right corner of the editor. Browse to the object you want, then click Add and it will appear on the ground.
| All times are GMT -8. The time now is 11:01 AM. |
