RCU Forums
-   RC Flight Simulator Software (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/)
-   -   Sim recommendation for a laptop (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/3938567-sim-recommendation-laptop.html)
shussey 02-20-2006 10:43 PM
Hi all,
I'm about to start traveling for work again and want to be able to take my hobby with me on the road.
I'm wondering what sim ya'll recommend for a laptop....Currently running a Dell Latitude D400 with 1 MB of RAM.
I currently have the FMS freebie at home on my desktop, but am looking at a commercial version either G3, Aerofly or Reflex.
Any thoughts or input would be much appreciated.
huminski 02-21-2006 03:09 AM
RE: Sim recommendation for a laptop
I'm running G2 on an IBM R51 (1.6GHZ, 512mb RAM, 32MB ati radeon Mobile) and a Toshiba Satellite 1.6ghz 256MB, both run fine.
Can't tell you about G3 because I don't have it, and based on my experience getting support and updates for G2 after paying over $300 for it and the add ons, I will not ever buy anything from knife edge again.
STLPilot 02-21-2006 06:25 AM
What video card do you have?
rjm1982 02-21-2006 07:44 AM
Look into the HP ZD 8000 series...
I custom'ed one and it runs G3 nice, the best part is the high resolution 17" widescreen, and the fact that the keyboard has a full numpad on it too..
My specs
P4 3.4Ghz with Hyperthreading
1GB RAM
ATI Radeon x600 with 256MB of its own ram.
100GB Hard Drive (7200 RPM)
The only downside is its a beast. It weighs close to 10-12 lbs. Its heavy for a traditional "laptop", but its a desktop replacement. It also eats the battery rather quick, between the Huge screen, the high-speed hard drive, and the fact that its a Desktop processor rather than a laptop one, you might get an hour on a battery.
It really depends on how you use it. You you need it to be in your lap, this would get uncomfortable after about 10 minutes. If you would just be using it in your hotels or at meetings, etc...then this is great. I have yet to choke this machine, G3 runs beautifully, and i do alot of work in 3d Studio with it too...it handles everything with ease.
You can also order this as a media machine (i chose XP Pro for specific reasons) with Windows XP Media Center Edition and an external USB2.0 Dual TV Tuner...and even without the media center stuff, it plays DVDs awesome, throw in the Altec Lansing speakers that line the fron of the machine, and you will forget your watching on a laptop, best sound quality on any laptop ive ever seen.
(can you tell i like this machine)
j
louis cypher 02-22-2006 02:31 AM
I have a HP Pavillion ZD8000....Batteries last, as you say, not long. I may get 1 1/2 hours on a good day.
This will support A reflex XTR sim wont it..?
louis cypher 03-03-2006 01:48 AM
Is there a way to make the diplay come up on the T.V. ? Do you need a special type of lead to connect the p.c and television up ?
Charlie 03-03-2006 05:54 AM
1 Attachment(s)
Yes, all you need is a S-Video cable.
rjm1982 03-03-2006 08:36 AM
It depends on the laptop and the tv.
If your laptop has a s-video you can use that as long as your TV does.
If you have an HDTV, they you probably have a VGA connection on it...in that case, use that. Most laptops have a VGA out...its much higher quality than s-video...
I play on my 42" Plasma most times....is nice!
fireplug1111 03-13-2006 10:46 PM
I use my laptop with reflex and it wors great.
Now about the svideo cord How does that work. I jus thook it up to my laptop and then to the TV. Does it have to be on a certain channel?
tadracket 03-14-2006 12:37 PM
ORIGINAL: shussey
I hope you left out the 5 and 2 in your ram figure. I could not find where a video chip was an option for that computer. That will hinder your performance a little. The low end processor was 1.3 I think. Not bad. I would buy the top sim out there (AFPD, Reflex, G3) and worst case scenario, you run it at low detail. You still have a good sim that you can run on your desktop (if it is up to it). I used the free stuff for a while but AFPD was the best RC purchase I had made in a long while.
louis cypher 03-20-2006 02:47 PM
ORIGINAL: fireplug1111
What i had to puchase was a S video cable and a SCART socket adaptor. The SCART adaptor has the facility to accept various types of lead from your PC/laptop. Just connect up, select an AV channel on your tv and run the simulator.
t to the maxx2 03-25-2006 04:58 PM
I too have a zd8000
Processor Intel Pentium 4 3392MHz
Display Card ATI MOBILITY RADEON X600
Memory 2048MB
Operating System Microsoft Windows XP
Free Disk Space 35.32GB
Display Card Memory 256MB
Display Driver Version 6.14.10.6530
DirectX Version 9.0c
Optical Drive CD/DVD
Sound Card Conexant AMC Audio
Is that going to run g3 ok?
