Fms Problem
I made the serial interface for FMS, I am using a JR 388S radio and the signal is very unstable. Calibrating won't help. Signal out to serial looks stable in my osciloscope.
Any clue ? Thanks! |
Fms Problem
Did you make the "standard" or the PIC interface
FMS
I made the standard serial interface
Fms Problem
I've had a lot of trouble with JR in the past because of the low voltage floating output. You might have better luck using the JR specific version at http://www.customelectronics.co.uk/fmscrktj.htm or mine at http://members.lycos.co.uk/SteveLewin/index.html (which is just an extra transistor on the front of the standard version).
Steve |
Fms Problem
I am using the circuit with 2 transistors and the signal is very stable at the output towards the PC ( pin #9), I can see it with the osciloscope.
All I am getting is unbstable movements when in the calibration screen and of course the model is unflyable. Thanks |
Fms Problem
I might have a defective component.
I will check and I will let you know guys. Thanks for your kind support. Keep in touch ! |
| All times are GMT -8. The time now is 09:14 PM. |
