Add on 4 with XP, any problems?
I loaded the add on 4, it loaded fine but now when I select the G2 programs with the short cut icon on my desktop my computer crashes. This happen only when I use that short cut and only after I loaded the add-on 4. Anyone with similar problems?
Thanks, Bruno |
Add on 4 with XP
Just loaded my #4 and I use XP pro.. everything is A-OK!
(sounds very strange) keep us up-dated if you figure out the problem. Thanks Jeff Oh , and BTW I will NEVER go back to 98! :p |
I'm with you on that one!
Running XP with Add-on 1-4 with no problems!
Just upgraded lite to G2 with add ons 1, 3, and 4 no problems GOOD LUCK
You said it only happens when you use the shortcut? Then delete the shortcut and make a new one by right clicking the G2 exe Icon in the real flight folder, and then making a copy that you can paste as a shortcut back onto your desktop.
Note: when adding add on 4 this automatically installs a newer version of the G2 exe than the 570 version (Version 591). |
| All times are GMT -8. The time now is 07:22 PM. |
