Tru Flite Setup
I'll try again witth a better title. Does anyone have these stas for a Caliber 5 9for Tru Flite 3D?
Main Rotor Profile Drag Coefficent: 0.010cd - 0.300cd Weight: 50g - 400g Blade Cord: 20mm - 100mm Rotor Diameter: 1200mm - 1850mm Pitch at Max C/L: 10.0deg - 18.0deg Max C/L: 0.5cl - 2.5cl Pitch Curve Collective Pitch Travel Top: 0deg - 16deg Centre: -10deg - 10deg Bottom: -16deg - 0deg Cyclic Pitch Travel Roll +/-: 3deg - 10deg Pitch +/-: 3deg - 10deg Control Rotor Paddle Weight: 1g - 75g Area: 5sqr/cm - 100sqr/cm Fly Bar Diameter: 250mm - 800mm Tail Rotor Blades Rotor Diameter: 200mm - 400mm Cord: 20mm - 60mm Control Pitch at Servo Centre: 1.0deg - 10.0deg Total Pitch Movement: 5.0deg - 30.0deg Gyro Gain Gain A: 0% - 100% Gain B: 0% - 100% Response Time Speed: 100ms - 500ms Static: Single Rate/Dual Rate/Proportional/Heading Lock Air Frame Parastic Drag Cd: 0.01cd - 0.40cd Dimensions Total Weight: 1.50kg - 10.00kg Weather Vane: 1.0 - 10.0 Tail Rotor to Mast: 300mm - 1500mm Transmission Gear Box Ratios Engine/Main Rotor: 7.0:1 - 20.0:1 Engine/Tail Rotor: 2.0:1 - 8.0:1 Clutch Engage RPM: 2500rpm - 8000rpm Main Rotor Rotation: Clockwise/ Anti Clockwise Engine Maximum Power: 0.50bhp - 4.00bhp Maximum RPM: 6000rpm - 35000rpm |
| All times are GMT -8. The time now is 07:23 AM. |
