planes for FMS
I am looking for these planes (FMS):
F86 SabreJet P47 Thunderbolt good flying Pattern plane BigStick (UltraStick) THNX4 helping |
planes for FMS
no such thing as a good flying pattern plane in FMS, it doesn't use side area and so wont knife edge, and hanging is also a problem.
there is a huge German site which i got 90% of my planes from, it has the G-trick 90 in 3 different versions for different flying, same gos for Majestic and Sensation. type FMS in any old search engine and enjoy a days searching and downloading. don't have a Sabre yet, but if you find one let me know so i can turn it into a Wattage F-86 and put it on my site with the Sabre review |
planes for FMS
planes for FMS
phillybaby
THNX for the F-86...NICE!
by the way are you really from Philadelphia? I passed through this summer on my bike (vacation trip). Me and my wife really enjoyed the old city. My camera broke down, so we were riding around down-town shops looking for a used Minolta to fit my lenses - MAN WAS IT HOT in the leathers !!!!!!!!!!!!!!!! Anyway good to meet you :D P.S. if you are, you moved very far from home (I see you live in the UK )LOL |
planes for FMS
why is it only Americans that think this :p
no, my names Phil, and it was a nick name given to me by a online friend, it kinda stuck. Anyway, not a nice F-86 ;) i've had a play with the PAR file and got it as close to flying like my Wattage sabre as i can, inculding the DF noise. i will upload the files to my site soon or just mail me for a copy of the Par file which you can make a copy of the whole plane in a different folder, then replace its PAR file with mine |
phillybaby
f-86 please e-mail me the whole file if you can...
THNX phillyboy! :D (I'm not sure, but it could be illegal to call yourself Philly* if you are NOT from Philadelphia!) question1: I have a nice FMS Spit, flies well, but the rudder is to sensitive- how can I edit the rudder commands? question2: I have noticed one can't nife-edge in FMS. Do you know why that is? By-the-way I an NOT American (am Canadian) but I guess that's close enough for you folks living on the other side of the big pool *lmao* |
planes for FMS
you need to open the PAR file with notepad, its all in German sooooooo....
0 1:Type(-) Type[0=Plane] ParDesigner Ver0.8 4 2:Tmax(N) Maximum Thrust 1.8 3rmax(rad) Maximun Rudder Angle 1.4 4emax(rad) Maxmim Elevator Angle 0.4 5amax(rad) Maximim Aileron Angle 1.0 6:CLmax(-) Maximum Lift Coefficient -1.0 7:CLmin(-) Minimum Lift Coefficient 1 8:CLa(/rad) Lift Gradient 20 9:CLaSt(/rad) Lift Gradient in Stall 0.02 10:CDw(-) Drag Coefficient of Wing 0.01 11:CDb(-) Drag Coefficient of Fuselage 0.1 12:mug(-) Friction Coefficient of Wheels 0.1 13:dCDSt(-) Rise of Drag Coefficient in Stall 0.03 14:CM(-) Moment Coefficient 0.00 15:alpha0(rad) Wing Angle 1.5 16:b(m) Wing Span 0.6 17:c(m) Wing Chord 0.45 18:hce(m) Equivalent Center of Gravity 0.2 19:m(Kg) Mass 1.2 20:Izz(Kg*m^2) Yaw Inertia Moment 1.2 21:Iyy(Kg*m^2) Pitch Inertia Moment 0.1 22:Ixx(Kg*m^2) Roll Inertia Moment 1.5 23:She(m^2) Effective Area of Stab 1.5 24:Sfe(m^2) Effective Area of fin 1.5 25:Lt(m) Tail Moment Arm 0.000 26:VForm(-) Effect of Dihedral Angle use that, these are random figures but will tell you line by line what is what, this will allow you to edit the rudder, here you can see rudder is 1.8, this isn't degrees, i have no idea what it is, just type a new number ( sabre uses 0.09 for ailerons! ) save the file, reload the plane and see what difference it makes. putting - ATV on your transmitter will also work FMS doesn't have side area and so you end up using engine power and rudder, I've not found a plane even close to correct, same happens post stall which makes prophanging all but impossible, its possible to hang. but nothing works once your there. my F-86 is now zipped into a nice small file, i've put it on my sabre review, but currently cant get the link to work, I'm new to www.homepage.stuff so maybe a link to a file on the server wont work and it needs its own page. will sort this tomorrow, but just for you i'll post it in a min, just unzip it in your models folder. i;m currently having a Cougar done, and if i work out the design software i'll add a Magnum and a few of my other planes. theres a big difference between yanks and Canadians, in SouthPark you all have strange heads :p |
planes for FMS
Wattage sabre now working and cand be downloaded via my Sabre review
www.philsrcworld.fsnet.co.uk/sabrereview.htm |
planes for FMS
THNX Phillyboy for the info.
I looked at the WATTAGE review..... good stuff! but I can't find the Sabre download, can you point me to it? have no idea what's going on in SouthPark, but my head looks OK to me! |
planes for FMS
second page, update 2 right at the bottom, pic of the sabre on the left side
planes for FMS
GOTit!
one more thing, the Fury DWGS: do you have the same as on your page, but biger file size? if yes please e-mail to : [email protected] THNX p.s. the little thing flies pretty well! |
planes for FMS
For all of you thinking my Sabre flew too well its because i uploaded the wrong F-86. revisit the site to download the Wattage version. Pls let me know if it sounds like a jet or DF this time :D
planes for FMS
You sure fooled ME! *LMAO*
planes for FMS
turns out the thing is WHITE now!!!!! file re zipped and uploaded again....
| All times are GMT -8. The time now is 06:30 AM. |
