Vista
Has anyone used RealFlight 3.5 with Vista operating system? If so, are there any issues to get it to work properly?
RE: Vista
ORIGINAL: pagdpm6999 Has anyone used RealFlight 3.5 with Vista operating system? If so, are there any issues to get it to work properly? One issue I'm sure of is the performance hit you'll take... G3.5 runs at least 10 or 15% slower on Vista vs. running it on WinXP... -Case |
RE: Vista
ORIGINAL: CanCanCase ORIGINAL: pagdpm6999 Has anyone used RealFlight 3.5 with Vista operating system? If so, are there any issues to get it to work properly? One issue I'm sure of is the performance hit you'll take... G3.5 runs at least 10 or 15% slower on Vista vs. running it on WinXP... -Case |
RE: Vista
You would think that with 5 years in the making and $6 Billion spent it would work properly! That is one of the known truisms in data processing management that is known to be true. And it works perfectly however many programmers you have to assign to the task. |
| All times are GMT -8. The time now is 02:24 AM. |
