RealFlight 3.5 problem
Hey guys,
After I upgraded V3 to V3.5 with an upgrade disc my MX400 heli won't take off. The Aircraft Editor shows three cells in series but a total voltage of only 4.2 volts. One cell. The total voltage amount is in a grey area and doesn't change when I put the cursor on it. How can I change the grey areas so they can be edited. Also when launching the MX400 I get an error nessage "lipoly 1500mAh battery not found, default will be substituted". Does GP have a stash of battery downloads somewhere I don't know about? Thanks, Chris Hogan Miami, FL |
RE: RealFlight 3.5 problem
ORIGINAL: IMAC781 Hey guys, After I upgraded V3 to V3.5 with an upgrade disc my MX400 heli won't take off. The Aircraft Editor shows three cells in series but a total voltage of only 4.2 volts. One cell. The total voltage amount is in a grey area and doesn't change when I put the cursor on it. How can I change the grey areas so they can be edited. Also when launching the MX400 I get an error nessage "lipoly 1500mAh battery not found, default will be substituted". Does GP have a stash of battery downloads somewhere I don't know about? Thanks, Chris Hogan Miami, FL |
| All times are GMT -8. The time now is 08:49 AM. |
