How to setup JR10X to use with Reflex?
Dear all,
any body knows how to setup JR 10X radio to use with Reflex? Cause when i try to check pitch->throtle, the heli in reflex always keep rotating. I try to set the Gyro, still can not success. What should i set? on Gyro, what value, or another place parameter? I used to use with JR X3810, it works. Please advise. Thanks n regards, andrew. |
RE: How to setup JR10X to use with Reflex?
Dear all,
About "How to setup JR10X to use with Reflex?", it solves by me but not 100% solve... still need help! i asked to Reflex support for my problem (how to setup JR10X with reflex), and they tell me to just disable all heli program and set to airplane mode without any mixer and start throtle stick in center position. My question is, how do i setup my JR10X heli version to airplane mode? Cause JR10X radio just has 1 application per version. But the haven't reply yet until now. What i've tried is just reset my radio memory that reserves for the reflex, set the subtrim to be 50% so then i can start my throtle at lowest position. This setting can work with Align T-Rex electric heli reflex model(with checkbox of pitch->throtle is cheked). But still the heli keep rotate around 1 turn at first take off and still has anomali movement when use the rudder. Well, at least i can fly the heli within the reflex. The other problem that still exists, when use engine heli model and any electric heli model that has checkbox pitch->throtle is uncheck. The heli will not take off, like dont get enough power. Then i try another think, set my throtle trim to the lowest position, make throtle curve start from 0 and increase subtrim to be 150%, this setting can solve not enough power problem. So i can fly with any heli within reflex. The rest problem is every heli still keep rotating, fast when i use training mode within reflex!!! :(( I just think that the setting is still not correct. Please anyone help me to setup JR10X radio to use with Reflex XTR... |
I just want to inform, that after few hours do some settings on my JR10X, using Reflex-Sim, I'm very happy with the result. The problems have been solved. Mr. Maleika from Reflex inform me that some of the problem is throttle level, so I set some value on throttle curve and pitch curve, this setting solve heli keeps rotating problem. The other thing, why the heli has anomaly when make a turn with rudder stick, except mechanical gyro option is chosen, is caused wrong channel on Gyro sensibility, JR10X uses channel 8 for AUX3, and REFLEX default is channel 7. After these settings, every heli flies perfect. :D. Anyway, thanks to all.
Another thing, JR10X hhhmmmm... |
| All times are GMT -8. The time now is 01:56 PM. |
