interface cables
If you use a interface cable with your own radio, does your radio use power from your batteries or power through the cable?
Thanks for any input! |
interface cables
Or to actually answer the question - it normally uses the battery. It would be possible to power the Tx through the cable but none of the standard cables I've seen actually do it.
Steve |
| All times are GMT -8. The time now is 10:01 AM. |
