RCU Forums
-   RC Flight Simulator Software (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/)
-   -   Installing Ikarus (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/674471-installing-ikarus.html)
blue ice 04-06-2003 04:48 AM
Installing Ikarus
HELP!!!! While trying to start Aerofly Pro,my pc will not detect the game commander even after I added it to my game controllers. Any ideas?
chappy007 08-07-2003 10:18 PM
AERO FLY PRO
I am still working on getting mine up but it is my understanding that you must not only plug in the game commander, but also have the adapter for your own Tx (Even if you are not going to use your Tx) to have the program recognize it.
Good luck,
Chappy007
whidbey1 08-08-2003 12:02 AM
Installing Ikarus
Hi
I had the same problem, I fixed the problem by buying a usb adapter from Radio Shack.
Mike Ledbetter 08-08-2003 02:06 AM
This is what worked for me
I connected the game commander to the joystick port on the sound card and calibrated it. I connected the dongle to serial port #2. I started AeroFly Pro, move the mouse just a hair, wait 10 seconds for the program to detect the dongle and I'm flying.
The dongle also connects my Futaba 6X with no problems.
Hope this helps.
pentolino 01-29-2005 12:33 PM
RE: This is what worked for me
I use An Eclipse Hitec with a Serial interface that PPjoy recognize very well and that let me play with Realflight G2.
BUT I can't use it with aerofly pro!
It works using a USB joypad, but "Dongle Emu 10.0.0.10 by THQ" doesn't recognize the radio...
A friend of mine said that with WINDOWS ME it will works perfectly, but I actually have XP installed as OS so...
please help! I think it's a ports management problem
fuadramsey 02-28-2005 01:42 PM
How do you have this setup (the hitec radio on realflight and ppjoy). I'm trying to get my Laser 4 to work in Realflight G2 using a serial cable interface and ppjoy, but throttle (channel 3) is not being detected in Realflight G2.
fuadramsey 03-01-2005 12:19 PM
Here is a fix for setting up Realflight G2 with a Hitec transmitter (laser 4) using a serial interface (that works with FMS) and PPJOY (vitual joystick driver). With this setup, you can use your transmitter as a joystick for any program that will allow the use of a regular joystick!
When I first set it up, I found out that there were people having trouble getting the throttle (channel 3) to work in Realflight G2. Here is how I fixed it (with the help of other postings).
Get details and see photos at the thread I started at rcgroups.com:
http://www.rcgroups.com/forums/showthread.php?t=341275
