RCU Forums
-   RC Flight Simulator Software (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/)
-   -   FS One Throttle won't work! (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/7183860-fs-one-throttle-wont-work.html)
Carroll-RCU 03-06-2008 08:54 AM
I just bought a used FS one unit with the Tacon radio and after downloading the upgrades to 1.0.9 the prop on the plane just barely turns at full throttle until I use the shift key on the keyboard. As long as I hold down the key I can fly the the plane. All other controls work perfectly. Any help would be appreciated.
Carroll
"FS One has stated my TacCon controller was bad causing the throttle problem"
whidbey1 03-07-2008 07:43 PM
RE: FS One Throttle won't work!
HI
Have you tried to calibrate the controller, their calibration is kind of complicated, I thought mine was messed up too, but that fixed it.
Good Luck
Bill
Carroll-RCU 03-08-2008 10:23 AM
Calibrated it several times with no luck. I just ordered a new one (they're only 29.95). Then the crazy controller started working.
Go figure!
Carroll
