G4 Help
I just installed G4 on my new gateway. The screen seems to be jumping from frame to frame. Is it possible I don't have the right graphics?
My PC is brand new Gateway. The graphics are: Intel Graphics Media Accelerator 950 Up to 224 MB Shared Video Memory I am running Windows Vista and duo core processor. How do I get into the control panel to jack up the video memory? Does this thing absolutely need dedicated memory for the video? |
RE: G4 Help
I also have a question, When will G4 be fixed so it will accomadate the Add On Disks 1 through 5?
NEDYOB |
RE: G4 Help
Shared video controllers = "ca ca".
You cannot do anything about this if you have a laptop, but most Desktop systems can be upgraded to better video adapters. Re: "When will G4 be fixed". Well a "fix" is not needed as the add-ons were really designed for G2 and were not to be supported in G4... However KE is working on a patch to enable backward compatibility. It's in testing now. So the answer is SOON. |
RE: G4 Help
Thank you for the reply on the Add On Disc, good to hear they are checking into it.
NEDYOB |
RE: G4 Help
ORIGINAL: opjose Shared video controllers = "ca ca". You cannot do anything about this if you have a laptop, but most Desktop systems can be upgraded to better video adapters. Re: "When will G4 be fixed". Well a "fix" is not needed as the add-ons were really designed for G2 and were not to be supported in G4... However KE is working on a patch to enable backward compatibility. It's in testing now. So the answer is SOON. I have a desktop, so I might be able to expand? |
RE: G4 Help
Heh, a term for "shee - it".
Since you have a Desktop you can upgrade easily. There are some rather amazing cards to be had for decent prices. I spent well over $550.00 for an Nvidia 8800 Ultra. Now you can buy just about the same thing for $130.00 with 256mb of dedicated video RAM... |
RE: G4 Help
Do you know where? Do you have a link? Thanks
RE: G4 Help
RE: G4 Help
RE: G4 Help
You'll do better with Nvidia cards.
RE: G4 Help
How can I be sure my PC will accept a card? Arent some integrated?
RE: G4 Help
My specs are:
Add-in Card Slots: One PCI Express ×16 (graphics interface) One PCI Express ×1 Two PCI conventional So that sounds like the ATI Radeon card would work in the PCI Express x 16 slot Apparently, this nvidia would too http://www.bestbuy.com/site/olspage....=1186007060320 |
RE: G4 Help
For the price of the 8500 there, you can pick up a much better one at newegg.com
[link=http://www.rcuniverse.com/forum/m_6300298/anchors_6300298/mpage_1/key_Nitroplanes%252CTucano/anchor/tm.htm#6300298]Click me![/link] However with the nvidia card, the second number e.g. x500 versus x600 determines the chipset used. The higher the better. But I would strongly suggest you spend a little more and get say an 8800GT [link=http://www.newegg.com/Product/Product.aspx?Item=N82E16814125089]8800GT[/link] Which works out to only $159.00 with rebate for great performance and DX10 compatibility. |
RE: G4 Help
Thanks for the help. I ordered today and will try the card. I will let you know how it works out.
RE: G4 Help
I agree, I have the 8800GTS with 640 megs and its unbeatable. I also run Microsofts Flightsim X Deluxe, which is known to be the worst hardware hog on the market and it runs it very smooth.
RE: G4 Help
I ordered the card a few days ago and finally installed it today. My G4 works now without the skipping. The card was really easy to install also. Thanks for all of your help.
| All times are GMT -8. The time now is 06:51 AM. |
