RCU Forums
-   RC Flight Simulator Software (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/)
-   -   FMS Tx cable help? (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/7274244-fms-tx-cable-help.html)
vasek 03-24-2008 10:29 AM
FMS Tx cable help?
Hi,
I have a Tx cable with a "9 pin game port" connector (from my old comp).
Can I just change the connector to USB? will it work?
ggunners 03-24-2008 10:48 AM
RE: FMS Tx cable help?
No. You need another 9-pin game connector to make that work. Sometimes all you need is a cable that connects to your computers motherboard to provide the game connector, so check your motherboard specs to be sure.
Otherwise, you'll need to purchase a USB cable for your transmitter.
-- ggunners
vasek 03-24-2008 11:34 AM
1 Attachment(s)
ggunners,
i do have what appears to be serial port in my laptop , however it is of a different pin configuration > 15 pin.
If i change the 9 pin plug to 15 pin plug, will it work?
If yes, there are 3 cables connected to the 9 pin plug ( red ; orange ; black ) how do i know where they go in the 15 pin plug?
flyX 03-24-2008 11:52 AM
it should.
it should with the USB connect too, because not all the pins are being used on the D-sub.
You have to know which wire gose to want pin for the USB thou.
look in the FMS's Folder
C:/Programfiles/FMS
You'll see instructions and diagrams for D-sub.
Another way around it, is to just use SmartPro.
There's a link to it on FMS's site
It plugs into the mic phone jack.
download the correct file for your TX and the correct file of how you want to use it.
There's also diagrams for different TX trainer plugs.
vasek 03-25-2008 07:27 AM
flyx, thaks for the info
