G3.5 Problem
I have had RealFlight G3.5 for quite a while. It has been running fine.
Today, when I ran it, it loaded the terrain fine then the Airport Objects took around 3 seconds each. WHen it finally loaded, the response was a couple of orders of magnitude worse than it used to be. It took seconds to respond to any controll on the Interlink. I speant over an hour on the phone with Tech Support. I tried several different versions of the display driver with no change. To my knowledge nothing has changed on the PC since the last time I ran it. Anyone got any ideas? |
RE: G3.5 Problem
When I auto loaded the most recent program update, the whole sim headed south! After some fruitless attempts at repair, I just reloaded the whole thing, and it now works well. I had to go back to an earlier version before upgrading again to 3.50.065, but it did fix it. Good luck!
| All times are GMT -8. The time now is 06:10 AM. |
