RCU Forums
-   RC Flight Simulator Software (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/)
-   -   G2 glitching (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/757997-g2-glitching.html)
lennyk 05-09-2003 02:09 AM
G2 glitching
My G2 is glitching continously when flying, I have turned off and on the failure feature but it doesn't go away,
Nothing is wrong with the radio box because it doesn't glitch when calibrating or when I test the joystick from Windows.
Any suggestions short of reinstalling ?
L
Birddog-RCU 05-09-2003 02:29 AM
Your Computer
Tell us a little about your computer setup. What processor speed, video card, total RAM and other attached accessories running etc,
flygirl1 05-09-2003 08:44 PM
g2 glitching
Try updating your sound and video drivers. What sound and video are you using? If your video doesn't have alot of memory you may have to turn off some of your item visability things under the Airports menu.
Kyle300S 05-09-2003 09:06 PM
G2 glitching
have u tryed takeing out the trees? or takeing off the 3d background? doing these things help mine a lot and u dont have to worry about hitting trees when flying IMAC. try it and see if it helps.
lennyk 05-11-2003 07:28 PM
G2 glitching
The problem went away when I switched airports,
I even went back to the original airport and the glitching has stopped.
flygirl1 05-12-2003 01:09 PM
G2 glitching
It was probably a background application running then. If you experience this again you may want to shut down any background apps you have running. ;-)
