RCU Forums
-   RC Flight Simulator Software (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/)
-   -   Who Can Answer It? (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/907226-who-can-answer.html)
PHIL I. 06-29-2003 01:07 AM
Who Can Answer It?
:D :D
I got a good one that NO one has answered yet!
I have a G2 lite with Tx with interface!It is made by FUTABA. Will it work with any other sim? Like the FMS. There have been a few questions asked but NO answers. With my luck, eventho the Tx is made by FUTABA, It will not work on other sims!!!
:D :D
PHIL I.
Eric Brouwer 06-30-2003 05:33 AM
Who Can Answer It?
If the interface plugs into the game port, it should work with all software that has joystick suport. However, if it's a printer port interface, it will only work on RealFlight.
PHIL I. 06-30-2003 06:26 PM
input!
Its the USB port on the front of thw tower.. :)
PHIL I.
FlyBoyDavid 07-03-2003 10:34 AM
Who Can Answer It?
Why not just try it in a game. If you have one... I'm going to say it will. The interface bassically just turns your radio into a glorified joystick anyway. And if it's USB. It's more than likely going to work with other sims/games. Worth a try.
Nige 07-03-2003 11:40 AM
Who Can Answer It?
The G2 USB interface works with Aerofly Pro and FMS (the other two sims I have) as it is seen as just another "Game Controller"
PHIL I. 07-03-2003 06:35 PM
THANKS GUYS!
:cool:
From what I have found SO far is, if a port, serial or parrallel, is used the controller will not work.If the USB is used, it is thought to be a game controller, not an R/C unit.
Am I right? Or dreaming?
:cool: :cool:
PHIL I.
tiggerinmk 07-03-2003 06:55 PM
Who Can Answer It?
Phil,
To answer the general question first: If you have a sim that comes with a serial or parallel Tx lead; generally, that lead will only work with the specific sim.
eg my FMS printer lead only works with FMS, my Easyfly serial lead only works with Easyfly.
I also have the Ripmax RC Sim. This comes with a game port lead and a seperate Windows driver that allows you to use the Tx with any joystick driven game.
Now G2: I've got the USB interlink. When you start the sim, if you haven't got the interface plugged in the software won't start. Hence you have to use the interlink interface, you can't use a different lead.
To answer your question, plug in the interlink controller. After a coulple of seconds the USB light should start flashing. Then go to the control panel and select 'Game Controllers' (or whatever your version of Windows says'). If there is an entry in the game controller window then you should be able to use the interface as a USB joystick....
PHIL I. 07-04-2003 05:56 PM
THANKS ALL.
Thanks all for the returns....It has helped much!!
PHIL I.
tiggerinmk 07-04-2003 10:52 PM
Who Can Answer It?
After my post I felt I had to try it out to see if the G2 controller is listed under 'gaming options'. Yup, it's listed as 'I-controller' and seems to respond to the test ok. I haven't tried it with a sim though (other than G2)...
chris100 07-05-2003 06:53 PM
Who Can Answer It?
The USB interface will work with other stuff. I use mine for FMS, MS Flight sim and even Nascar 2002. :)
PHIL I. 07-06-2003 06:20 PM
It Worked!!!
:D :D
I tried it and it worked. I used the joystick option, had to reset which number controles worked what! I have it set for standard 4
channel.
Now to experiment how to set everything else......
:D
PHIL I.
Thanks to ALL for the input guys.......
