Reflex USB Cable Help!
The male 3.5" plug broke where the wire enters the back of the plug. When I took the plug apart, the green and black wires were soldered on to the plug. The red wire was not connected, however the white wire was stripped and exposed as well as the outer copper shielding for the cable. Can anyone tell me if the white wire and outer sheathing get connected?
Thanks, SJS |
RE: Reflex USB Cable Help!
ORIGINAL: SJS Can anyone tell me if the white wire and outer sheathing get connected? |
Its the 5.05 dongle, and the male 3.5" mono plug for the JR 9303. The wires broke just before the plug that goes into the tx.
Sorry, in this case I can't help. Maybe you look at the other website or at [link=http://www.rc-sim.de/]http://www.rc-sim.de/[/link], there are people who have the same tx.
USTIK, the link you posted does not work in my browser but Im in need of the same thing. A USB for a JR radio and can't find one anywhere!!!! YIKES!
Should work now. Maybe [link=http://www.mftech.de/buchsen_en.htm]this one[/link] helps, if you just need to re-solder the JR plug.
UStik: Thanks for the prompt response, thanks!
| All times are GMT -8. The time now is 09:35 AM. |
