LEO .46 Glow Engine - home made fuel
hello,
i will start breaking in the leo .46 engine, i was thinking about using home made fuel 20%Castor oil + 80% methanol because i will use 5 tanks and i don't like towaste thecommercialgallon on that
i was searchingaroundfor home made mixtures and i've seen lots of posts saying that ABC engines fuels is different
actuallyi didn'tunderstood what will be the difference in OS and ABC engines fuels (leo engine manual says that itstypically ABC engine)
so please advice what is exactly the difference ?
this home made mixture can do the job properly or not?
RE: LEO .46 Glow Engine - home made fuel
Not to worry, that fuel will be perfect for running in your engine. That's the fuel I use in all my engines (ABC, ABN, ringed etc) to fly with except for engines with iron pistons where I use 25% all castor.
i have been mixing my own fuel for almost one year. what people dont understand is if you mix 8 oz of methanol and 8 oz of nitromethane you DO NOT get 50% by 50%, has to do with molecule size. mixing your own is NOT easy. save your self trouble. buy your fuel premixed. there is NO good reason to mix it your self.
i made some calculations about the prices i found that mixing fule wont save any cost
in egyption punds 4 liter original 5% nitro fule costs 115 EGP roughly 21 USD
the mixture with 0% nitros will cost 100 EGP almost 17 USD which is nothing to save
i guess its a bad idea now and i will go for the original
ORIGINAL: moe7404
I've been mixing my own fuel for over 50 years but because I don't use nitro it's just a simple matter of mixing 1 litre of castor with 4 litres of methanol to get 5 litres of true FAI fuel. For iron piston engines (and for running in) I mix 1 litre of castor with 3 litres of methanol for 4 litres of 25% oil. The FAI fuel costs me a little under $10 per US gallon and the 25% oil costs about $11 per US gallon because of the higher price of the oil. The advantage of mixing yourself (apart from being much cheaper) is that you know what's in your fuel.
to:downunder i have said this so much iam getting tired of it. i do NOT mix by volume, or oz or weight.. i mix by specific gravity, ie hydrometer. thats what i was trying to say. iam not going to post about mixing my own fuel any more.
