Where to buy Sig Fuel in Tx?
Good luck on that. I've been flying Sig fuel for many years. I have generally been able to make a trip back to the St. Louis area about once a year and pick up a couple of cases at the hobby shop-s there. I hope you can find some place, as I only have a few gallons on hand.
It'd be cheaper to order it direct from SIG if you get more than a couple gallons at a time. They were gonna charge me $10 standard UPS ground shipping and $25/4-gal case for hazmat on top of the $20-25/gal fuel price.
TX
I used to run !5% nitro Red Max with 18% all castor in my Foxes. That was when I lived in El Paso which is high desert country - 4,000 feet.
CR
An Enya would sing for a little while on 20% nitro, but then a belch and a fart and there goes the glow plug. LoL. Kidding aside, when someone says "all castor fuel" that tells me zero synthetic oil. I rarely use synthetic oil now myself. PAG oils do not provide the protection that castor oil does, though it is great at cleaning varnish and carbon up. Most of not all fuel companies' shelf stock fuel is a castor/synth blend (80/20 or 70/30 synth/castor respectively). Some outfits like SIG or S&W will make a castor based fuel for you upon request.
I make all my own fuel for all of my engines. I use 20% castor in my ringed engines and tapered bore engines, and my lapped and bushed engines get 25% oil. 5-10% nitro. They seem to like it.
TX
According to the SIG website this store in Tyler is one of SIG's dealers.
CR
EDIT: Never mind this link, it's no good.
Here's the link to SIG's TX dealers page: http://www.sigmfg.com/cgi-bin/dpsmar...100.html?E+Sig
