Can I mix 15% nitromethane with FAI fuel. ?
CA
Can I mix 15% nitromethane with FAI fuel? I have 3 gallons of 15% and 3 gallons of FAI fuel. Both cans are unopened. If I mix both together or mix both together in small amounts will it dilute performance, but work??
Most engines I run are OS Max, K&B.
thanks.
thanks.
Will not be an issue. But then again, it would not be an issue to just use the fuel as is. At worst, you may have to make a small adjustment to the needle settings when making the switch. Which you might have to do after making your "custom" blend. Most of the world uses FAI fuel.
