RC Fuels Nitromethane, Castor Oil, Synthetic, heli fuel, 4 stroke, etc...Fuel Q&A is here!
Diesel Fuel??
Old 02-11-2004, 10:17 AM
Tim Wiltse-RCU
Tim Wiltse-RCU's Avatar
Default Diesel Fuel??
What is the mix ratio for model diesel fuel? Now of my local hobby shops carry it and I just am to lazy to order on the internet. This will be running in a converted Cox .049.
Take care,
Tim
www.hypercoloranodizing.com
Old 02-11-2004, 12:20 PM
Motorboy
Motorboy's Avatar
Default RE: Diesel Fuel??
Here are formula of dieselfuel. But your cox engine need higher ether around 40-50% balanced with kerosene + 25% oil. Can add 2-2.5% Isopropyl Nitrate.
Ether Kerosene Castor oil Isopropyl Nitrate
35% 35.00% 28% 2.00%
30% 43.75% 24% 2.25%
30% 47.50% 20% 2.50%
Jens Eirik
Old 02-11-2004, 12:51 PM
Tim Wiltse-RCU
Jens,
Thanks alot. Where would a guy track down Isopropyl Nitrate and ether?
Take care,
Tim
Old 02-11-2004, 03:53 PM
Motorboy
Motorboy's Avatar
Tim, i use to buy ether in apothek, but Isopropyl Nitrate are difficult to buy, then i has not knowledge about shop in U.S.A since i live in Norway.
To all folks in U.S.A, who are reading here, please give Tim a little help...
Regards Jens
Old 02-11-2004, 04:49 PM
maxtenet
This has the mixtures recommended by various manufacturers. Check it out!
http://www.carlsonengineimports.com/...eselinfo.shtml
Max
Old 02-11-2004, 06:25 PM
ajcoholic
My Feedback: (10)
Tim, you must be lost... 1/2A forum is over there!
AJC
my 1/2A mix:
50% ether
20% kerosene
30% castor oil
add 2% MEKP (polyester resin hardener) for an ignition improver, does the same thing as IPN but no problem to get it...
(Before I get the hounds of safety on my butt, remember use at your own risk, I take the risk as I cannot buy commercially made fuel here in Northn Canada....)
Old 02-11-2004, 07:24 PM
Tim Wiltse-RCU
AJC,
I'm not lost...yet!!!! I thought I would go to the source on this diesel stuff!!! I have a idea I'm working on and I have no knowledge about diesels.
Later,
Tim
Old 02-12-2004, 12:25 AM
Motorboy
Motorboy's Avatar
ajcoholic: add 2% MEKP (polyester resin hardener) for an ignition improver, does the same thing as IPN but no problem to get it...
Hi Ajcoholic, Is it same hardener we use for glassfiber?? Can i use difference brand of the polyester resin hardener or MEKP only?
Jens Eirik
Old 02-12-2004, 07:33 AM
ajcoholic
My Feedback: (10)
Jens,
MEKP = Methyl Ethyl Ketone Peroxide. Its not a brand name, but the chemical name for the oxidiser. As long as its in liquid form, and not a cream, you can use it.
Its worldwide use as a hardener for "fibreglass" resin (polyester and vinylesters) and also here in Canada it is sold with allmost all autobody putty and fillers, etc as a hardener as they are mostly polyester based products- makes it easy to get and cheap.
Just remember, untill it is mixed into the fuel and diluted, handle with care, ie not to be gotten on the skin, or eyes especially.
AJC
