RC Fuels Nitromethane, Castor Oil, Synthetic, heli fuel, 4 stroke, etc...Fuel Q&A is here!
mixing jugs?
Old 06-13-2002, 05:13 AM
Default mixing jugs?
Sy what kind of jugs can I use to mix fuel and combine fuel etc. Will a regular gas can work?
thanks
Old 06-16-2002, 07:48 AM
My Feedback: (62)
Default Stick out yer can
If you are referring to metal cans, yes they will work but with a couple of caveats. First, it would be wise to re-label it in a very obvious way. I've never run a lawn mower on glow fuel
Second, some metal cans have a coating/lining on the inside that may or may not break down and deteriorate in time. I was a big fan of metal awhile back. I seemed to get less condensation in my fuel when it was exposed to the sun during a flying session. Kinda got away from that practice because of the inner lining thing. Several manufacturers used to supply fuel in metal. Not sure if they still do or not, but that of course would be a different set of circumstances_bob
Old 06-17-2002, 12:30 AM
Powermaster uses the cans. Got a couple at WRAM.
You could also use the fuel jugs that racers use. They are made for it. Or, how about used fuel cans or bottles?
Old 08-06-2002, 07:21 PM
Yeah, I have a couple metal cans from powermaster and a couple of near empty plastic fuel jugs that I can use.
Thanks, guys.
Old 07-14-2003, 12:29 AM
Hi if there is a speed shop for auto. OR a shop that supports drag racing or circle track, they usualy have 5 gal. thick plastic cans. they are for the chem. that the racers use.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
