RC Fuels Nitromethane, Castor Oil, Synthetic, heli fuel, 4 stroke, etc...Fuel Q&A is here!
FUEL TANK CLEANING
Old 04-01-2004, 12:10 PM
LongRC
Default FUEL TANK CLEANING
What can I use to clean out old glow fuel form my plastic fuel tanks.
Old 04-01-2004, 12:12 PM
vinnie
Default RE: FUEL TANK CLEANING
Alcohol should work.
ifixairplanes
My Feedback: (9)
glow fuel will clean it. put a little in your tank, seal off your lines, and shake vigorously. i used this method many times. if not glow fuel, use alcohol, but its the same thing.
sean
Old 04-01-2004, 01:16 PM
Wayne Miller
Hi,
I just purchased a Sig Kadet Jr. at a swap meet and the bottom half of the tank was green and gummy from old fuel.
What I did was spray some WD-40 into the tank, sealed the opening and let it sit overnight. In the morning, I swished the the WD-40 around and poured it out. The tank came up like new.
Hope this helps.
Best regards,
Wayne Miller
Old 04-01-2004, 06:50 PM
Parkerm
I had one that had completely dried residue in it. I tried evrything to dissolve it with no luck. I finally poured a 100 or so BB's in it and rattled them around while watching TV. Makes a heckuva racket but it eventualy broke the residue up. A couple of rinses with fuel and it is as good as new.
Old 04-17-2004, 04:14 PM
T28RON
My Feedback: (32)
You are absolutly correct. The only differance was the cleaning agent. I used brake cleaner and shook the bb's for a few minutes a whala--sparkling clean. I have approx 50 tanks that I have acquired over the years that were in real bad shap. Now they are coming clean like new. Thanks a bunch. Ron (T28RON).
