RC Fuels Nitromethane, Castor Oil, Synthetic, heli fuel, 4 stroke, etc...Fuel Q&A is here!
fueling a incowl 46?
Old 06-06-2005, 07:08 AM
SBR_RV
SBR_RV's Avatar
Default fueling a incowl 46?
hi, i have my first model with which includeds a cowl, the tank set up has the vent line, fuel line and im guessing the other line is what a fill her up with.
the problem would be not being able to free the back presure line from the muffler to let over flow not get into the muffler.
do i put a mark on the tank and stop when it reaches that mark? or is there another way?
thanks.
Old 06-06-2005, 08:09 AM
joeb102072
My Feedback: (9)
joeb102072's Avatar
Default RE: fueling a incowl 46?
Fuel dots and T's. You can T the line from your back pressure and use a fuel dot they get drilled neatly into your cowl and the fuel dot stopper is used to cap the line after fueling. Most everyone that has an in cowl engine uses them. They are cheap and can be found at your LHS or from web sites like psp.com
Old 06-06-2005, 09:47 AM
downunder
downunder's Avatar
SBR...I can't really help more with your fuelling question but your avatar got me
The first pic is from an Adelaide air show and the second one (A8-142) is the plane I did a bit over Mach 2.3 in, before it got its grey paint.
ID:	281123   Click image for larger version
Old 06-07-2005, 07:25 AM
SBR_RV
SBR_RV's Avatar
thanks for the help joeb.
downunder, mach 2.3 [X(] what the heak was that like. i did a max of about 290km in a cheiftan.
BTW your avatar scared the **** out of me
Old 06-07-2005, 08:31 AM
downunder
downunder's Avatar
As smooth as silk, no noise, no vibrations. Now 450 knots at 300 feet over the Queensland country side letting the plane fly itself was something else
Errr..and to bring things back to the Fuels forum...33,000 pounds of kero you could use in model diesel fuel (now that's a stretch!).
