RC Fuels Nitromethane, Castor Oil, Synthetic, heli fuel, 4 stroke, etc...Fuel Q&A is here!
Can you have too much oil ?
Old 05-15-2003, 01:19 PM
Default Can you have too much oil ?
I am using Byron's 20% oil, 15% nitro in my O.S. 91 and BGX 3500 engines. The engines are well broken in.
Can using oil percentages of 20% be detrimental to the engines in any way ?
I know they should be protected from low oil %.
Thanks in advance.
Cary
Old 05-16-2003, 02:33 AM
To any reasonable degree there's no harm at all using high percentages of oil. The limit comes when the drag of oil begins to generate extra heat as well as a slight drop in revs but this won't happen until you're well over 30% or so. The amount of oil causes an engine to run slightly differently and I've used extra oil in my ST 51 (25% all castor) to change its characteristics.
Old 05-29-2003, 03:52 PM
A manuf. has comments on too much oil and other things.
http://www.rcuniverse.com/showthread...85#post1012631]
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
